10.07.2020, 21:40 Uhr
hier mal der Sketch, bisschen lang
Quellcode: |
#include <Time.h> #include <TimeLib.h>
Emulator DCF77 Simulate a DCF77 radio receiver with a ESP8266, esp01 model Emits a complete three minute pulses train from the GPIO2 output the train is preceded by a single pulse at the lacking 59° pulse to allow some clock model synchronization of the beginning frame after the three pulses train one more single pulse is sent to safely close the frame get the time from the ntp service
Uses Time library to facilitate time computation
Known issue: -When the DayLightSaving mode change, the three minutes packet is not checked for possible changes of hour across the frame itself, moreover the daylight saving is changed normally at 3 o clock in the morning (here in italy), while I don't correct for it so the time will be probably incorrect before at least 03:03 then dayLightSaving changes -the exact "second" precision is not guaranteed because of the semplicity of the NTP imnplementation normally the packet transit delay would be taken into account, but here is not
Fuso68 05/12/2015
19/12/2015 added disconnect and reconnect if wlan fail, reconnect also after three failed ntp requests 20/12/2015 increased wlan connect timeout to 30 seconds
Based upon: Udp NTP Client
Get the time from a Network Time Protocol (NTP) time server Demonstrates use of UDP sendPacket and ReceivePacket For more on NTP time servers and the messages needed to communicate with them, see http://en.wikipedia.org/wiki/Network_Time_Protocol
created 4 Sep 2010 by Michael Margolis modified 9 Apr 2012 by Tom Igoe updated for the ESP8266 12 Apr 2015 by Ivan Grokhotkov
This code is in the public domain.
#include <ESP8266WiFi.h> #include <WiFiUdp.h> #include <Ticker.h> //#include <Time.h>
char ssid[] = "your_network_name"; // your network SSID (name) char pass[] = "network_password"; // your network password
unsigned int localPort = 2390; // local port to listen for UDP packets
/* Don't hardwire the IP address or we won't get the benefits of the pool. * Lookup the IP address for the host name instead */ IPAddress timeServerIP; // time.nist.gov NTP server address const char* ntpServerName = "0.nl.pool.ntp.org";
const int NTP_PACKET_SIZE = 48; // NTP time stamp is in the first 48 bytes of the message
byte packetBuffer[ NTP_PACKET_SIZE]; //buffer to hold incoming and outgoing packets
// A UDP instance to let us send and receive packets over UDP WiFiUDP udp;
//udp reply missing counter int UdpNoReplyCounter = 0;
//routine timer 100 msec Ticker DcfOutTimer;
#define LedPin 2
//how many total pulses we have //three complete minutes + 2 head pulses and one tail pulse #define MaxPulseNumber 183 #define FirstMinutePulseBegin 2 #define SecondMinutePulseBegin 62 #define ThirdMinutePulseBegin 122
//complete array of pulses for three minutes //0 = no pulse, 1=100msec, 2=200msec int PulseArray[MaxPulseNumber];
int PulseCount = 0; int DCFOutputOn = 0; int PartialPulseCount = 0; int ThisHour,ThisMinute,ThisSecond,ThisDay,ThisMonth,ThisYear,DayOfW;
const int timeZone = 1; // Central European Time
int Dls; //DayLightSaving
void setup() { Serial.begin(9600); Serial.println(); Serial.println("INIT DCF77 emulator"); pinMode(LedPin, OUTPUT); digitalWrite(LedPin, LOW); //handle DCF pulses DcfOutTimer.attach_ms(100, DcfOut);
//first 2 pulses: 1 + blank to simulate the packet beginning //il primo bit e' un 1 PulseArray[0] = 1; //missing pulse indicates start of minute PulseArray[1] = 0;
//last pulse after the third 59° blank PulseArray[MaxPulseNumber - 1] = 1; PulseCount = 0; DCFOutputOn = 0; //we begin with the output OFF
//first connect to wifi network //NOTE testing WiFi.status() BEFThisHour the FIRST WiFi.begin() seems to hang the system //so we attempt a first connection BEFORE the main loop ConnectToWiFi(); }
void loop(){ //check the WLAN status if (WiFi.status() == WL_CONNECTED) ReadAndDecodeTime(); else ConnectToWiFi();
delay(60000);
void ConnectToWiFi(){ int Timeout;
WiFi.disconnect(); Serial.println("Disconnected !"); delay(1000); //necessary ??? Serial.print("Connecting to "); Serial.println(ssid); WiFi.begin(ssid, pass); Timeout = 0; while (WiFi.status() != WL_CONNECTED) { delay(500); Serial.print("."); if (Timeout++ > 60){ Serial.println("\nImpossible to connect to WLAN!"); WiFi.disconnect(); return; } }; Serial.println(""); Serial.println("WiFi connected"); Serial.println("IP address: "); Serial.println(WiFi.localIP());
void ReadAndDecodeTime() {
int DayToEndOfMonth,DayOfWeekToEnd,DayOfWeekToSunday;
//get a random server from the pool WiFi.hostByName(ntpServerName, timeServerIP);
Serial.println("Starting UDP"); udp.begin(localPort); Serial.print("Local port: "); Serial.println(udp.localPort());
sendNTPpacket(timeServerIP); // send an NTP packet to a time server // wait to see if a reply is available delay(1000); int cb = udp.parsePacket(); if (!cb) { Serial.println("no packet yet"); //try max 3 times (every minute) after that we force the wifi to reconnect if (UdpNoReplyCounter++ == 3){ Serial.println("Too many UDP errors"); ConnectToWiFi(); UdpNoReplyCounter = 0; }; } else { UdpNoReplyCounter = 0; Serial.print("packet received, length="); Serial.println(cb); // We've received a packet, read the data from it udp.read(packetBuffer, NTP_PACKET_SIZE); // read the packet into the buffer
//the timestamp starts at byte 40 of the received packet and is four bytes, // or two words, long. First, esxtract the two words:
unsigned long highWord = word(packetBuffer[40], packetBuffer[41]); unsigned long lowWord = word(packetBuffer[42], packetBuffer[43]); // combine the four bytes (two words) into a long integer // this is NTP time (seconds since Jan 1 1900): unsigned long secsSince1900 = highWord << 16 | lowWord; Serial.print("Seconds since Jan 1 1900 = " ); Serial.println(secsSince1900);
// now convert NTP time into everyday time: Serial.print("Unix time = "); // Unix time starts on Jan 1 1970. In seconds, that's 2208988800: const unsigned long seventyYears = 2208988800UL; // subtract seventy years: //note: we add two minutes because the dcf protocol send the time of the FOLLOWING minute //and our transmission begins the next minute more time_t ThisTime = secsSince1900 - seventyYears + ( timeZone * 3600 ) + 120; // print Unix time: Serial.println(ThisTime);
//calculate actual day to evaluate the summer/winter time of day ligh saving DayOfW = weekday(ThisTime); ThisDay = day(ThisTime); ThisMonth = month(ThisTime); ThisYear = year(ThisTime); Serial.print("Local time"); // UTC is the time at Greenwich Meridian (GMT) Serial.print(ThisDay); Serial.print('/'); Serial.print(ThisMonth); Serial.print('/'); Serial.print(ThisYear); Serial.print(' '); //check daylight saving Dls = 0; //default winter time //From April to september we are surely on summer time if (ThisMonth > 3 && ThisMonth < 10) { Dls = 1; }; //March, month of change winter->summer time, last Sunday of the month //March has 31 days so from 25 included on Sunday we can be in summer time if (ThisMonth == 3 && ThisDay > 24) { DayToEndOfMonth = 31 - ThisDay; DayOfWeekToSunday = 7 - DayOfW; if (DayOfWeekToSunday >= DayToEndOfMonth) Dls = 1; }; //October, month of change summer->winter time, last Sunday of the month //October has 31 days so from 25 included on Sunday we can be in winter time if (ThisMonth == 10) { Dls = 1; if (ThisDay > 24) { DayToEndOfMonth = 31 - ThisDay; DayOfWeekToEnd = 7 - DayOfW; if (DayOfWeekToEnd >= DayToEndOfMonth) Dls = 0; }; };
Serial.print("Dls:"); Serial.print(Dls); Serial.print(' '); //add one hour if we are in summer time if (Dls == 1) ThisTime += 3600;
//now that we know the dls state, we can calculate the time to // print the hour, minutes and seconds: ThisHour = hour(ThisTime); ThisMinute = minute(ThisTime); ThisSecond = second(ThisTime); Serial.print(ThisHour); // print the hour Serial.print(':'); Serial.print(ThisMinute); // print the minute Serial.print(':'); Serial.println(ThisSecond); // print the second
//if we are over about the 56° second we risk to begin the pulses too late, so it's better //to skip at the half of the next minute and NTP+recalculate all again if (ThisSecond > 56){ delay(30000); return; }
//calculate bis array for the first minute CalculateArray(FirstMinutePulseBegin);
//add one minute and calculate array again for the second minute ThisTime += 60; DayOfW = weekday(ThisTime); ThisDay = day(ThisTime); ThisMonth = month(ThisTime); ThisYear = year(ThisTime); ThisHour = hour(ThisTime); ThisMinute = minute(ThisTime); ThisSecond = second(ThisTime); CalculateArray(SecondMinutePulseBegin);
//one minute more for the third minute ThisTime += 60; DayOfW = weekday(ThisTime); ThisDay = day(ThisTime); ThisMonth = month(ThisTime); ThisYear = year(ThisTime); ThisHour = hour(ThisTime); ThisMinute = minute(ThisTime); ThisSecond = second(ThisTime); CalculateArray(ThirdMinutePulseBegin);
//how many to the minute end ? //don't forget that we begin transmission at second 58° int SkipSeconds = 58 - ThisSecond; delay(SkipSeconds * 1000); //begin DCFOutputOn = 1;
//three minutes are needed to transmit all the packet //then wait more 30 secs to locate safely at the half of minute //NB 150+60=210sec, 60secs are lost from main routine delay(150000);
udp.stop() ;
void CalculateArray(int ArrayOffset) { int n,Tmp,TmpIn; int ParityCount = 0;
//first 20 bits are logical 0s for (n=0;n<20;n++) PulseArray[n+ArrayOffset] = 1;
//DayLightSaving bit if (Dls == 1) PulseArray[17+ArrayOffset] == 2; else PulseArray[18+ArrayOffset] == 2; //bit 20 must be 1 to indicate time active PulseArray[20+ArrayOffset] = 2;
//calculate minutes bits TmpIn = Bin2Bcd(ThisMinute); for (n=21;n<28;n++) { Tmp = TmpIn & 1; PulseArray[n+ArrayOffset] = Tmp + 1; ParityCount += Tmp; TmpIn >>= 1; }; if ((ParityCount & 1) == 0) PulseArray[28+ArrayOffset] = 1; else PulseArray[28+ArrayOffset] = 2;
//calculate hour bits ParityCount = 0; TmpIn = Bin2Bcd(ThisHour); for (n=29;n<35;n++) { Tmp = TmpIn & 1; PulseArray[n+ArrayOffset] = Tmp + 1; ParityCount += Tmp; TmpIn >>= 1; } if ((ParityCount & 1) == 0) PulseArray[35+ArrayOffset] = 1; else PulseArray[35+ArrayOffset] = 2; ParityCount = 0; //calculate day bits TmpIn = Bin2Bcd(ThisDay); for (n=36;n<42;n++) { Tmp = TmpIn & 1; PulseArray[n+ArrayOffset] = Tmp + 1; ParityCount += Tmp; TmpIn >>= 1; } //calculate weekday bits TmpIn = Bin2Bcd(DayOfW); for (n=42;n<45;n++) { Tmp = TmpIn & 1; PulseArray[n+ArrayOffset] = Tmp + 1; ParityCount += Tmp; TmpIn >>= 1; } //calculate month bits TmpIn = Bin2Bcd(ThisMonth); for (n=45;n<50;n++) { Tmp = TmpIn & 1; PulseArray[n+ArrayOffset] = Tmp + 1; ParityCount += Tmp; TmpIn >>= 1; } //calculate year bits TmpIn = Bin2Bcd(ThisYear - 2000); //a noi interesa solo l'anno con ... il millenniumbug ! for (n=50;n<58;n++) { Tmp = TmpIn & 1; PulseArray[n+ArrayOffset] = Tmp + 1; ParityCount += Tmp; TmpIn >>= 1; } //date parity if ((ParityCount & 1) == 0) PulseArray[58+ArrayOffset] = 1; else PulseArray[58+ArrayOffset] = 2;
//last missing pulse PulseArray[59+ArrayOffset] = 0;
/* for debug: print the whole 180 secs array * Serial.print(':'); for (n=0;n<60;n++) Serial.print(PulseArray[n+ArrayOffset]);*/
// send an NTP request to the time server at the given address unsigned long sendNTPpacket(IPAddress& address) { Serial.println("sending NTP packet..."); // set all bytes in the buffer to 0 memset(packetBuffer, 0, NTP_PACKET_SIZE); // Initialize values needed to form NTP request // (see URL above for details on the packets) packetBuffer[0] = 0b11100011; // LI, Version, Mode packetBuffer[1] = 0; // Stratum, or type of clock packetBuffer[2] = 6; // Polling Interval packetBuffer[3] = 0xEC; // Peer Clock Precision // 8 bytes of zero for Root Delay & Root Dispersion packetBuffer[12] = 49; packetBuffer[13] = 0x4E; packetBuffer[14] = 49; packetBuffer[15] = 52;
// all NTP fields have been given values, now // you can send a packet requesting a timestamp: udp.beginPacket(address, 123); //NTP requests are to port 123 udp.write(packetBuffer, NTP_PACKET_SIZE); udp.endPacket(); }
//called every 100msec //for DCF77 output void DcfOut() {
if (DCFOutputOn == 1) { switch (PartialPulseCount++) { case 0: if (PulseArray[PulseCount] != 0) digitalWrite(LedPin, 0); break; case 1: if (PulseArray[PulseCount] == 1) digitalWrite(LedPin, 1); break; case 2: digitalWrite(LedPin, 1); break; case 9: if (PulseCount++ == (MaxPulseNumber -1 )){ //one less because we FIRST tx the pulse THEN count it PulseCount = 0; DCFOutputOn = 0; }; PartialPulseCount = 0; break; }; };
int Bin2Bcd(int dato) { int msb,lsb;
if (dato < 10) return dato; msb = (dato / 10) << 4; lsb = dato % 10; return msb + lsb; }
-- RECORD, CRN1; CRN2; PicoDat; LC80; Poly880; KC85/2,3,4,5 ; KC87; Z1013; BIC; PC1715; K8915; K8924; A7100; A7150; EC1834; und P8000 ab jetzt ohne Tatra813-8x8 aber mit W50LA/Z/A; P3; ES175/2 und Multicar M25 3SK; Barkas B1000 HP |
