21.07.2018, 21:40 Uhr
DKt
Hi Denis,
CASCO is a CASsette COpy program. It was written for older version of K8915. You need an AKB(045-8028) wired on Dd0h and a K5200 cassette drive or an K5221 dual cassette drive unit.
At least you need the adapted CASCO program. I can search for it and send it to you.
MODF is designed for A5120 / K8924 computer.
I don't know, why both programs reside on this disk.
INTE12 should work on your 8915. The screen content is ok actually.I don't know, why the intensity changes sometimes. Perhaps your ABS is configured differently.
Be careful while using INTE12, it is possible, that you destroy the content of the harddisk.
Drive letters of the harddisk start with f: , so that "DIR F:" should work.
The SCPX kernel on the a: disk contains the information on which cylinder the drives start.
Regards, Dirk |
