Robotrontechnik-Forum » Technische Diskussionen » Nummernsystem des Büromaschinenwerkes » Themenansicht
15.05.2017, 17:32 Uhr
soemtron220
Avatar von soemtron220
Hi,
Reference page - http://www.robotrontechnik.de/index.htm?/html/standards/benennung_bws.htm - Nummernsystem des Büromaschinenwerkes Sömmerda.
XX-YYY-ZZZZ-P
XX=Kennung für die Fertigungsstufe, Dokumentationsart
YYY=Kennung für das Gerät
ZZZZ=Baugruppennummer innerhalb des Gerätes
P=Prüfziffer
I believe, at least for PCB's (Leiterplatte) that "P" refers to the issue level of the board. Some PCB's were redesigned many times, especially for the ETR220, the xx-yyy-zzzz seems to stay the same but "P" changes.
Suchen nach einem PDP-7
16.05.2017, 22:16 Uhr
The number "P" is the checksum/ check digit of the part number itself. P depends only from xx, yyy and zzzz.
The issue level was set behind this number. It consists of a number and a lower case letter. The number was changed, if the modification was extensive and the letter was changed, if the modification was small.
example: 05-489-2010-5 0a --> 05-489-2010-5 0b
If it is a double sided board there is inserted a "B" for the upper side layout or a "L" for the bottom side layout between the part number and the issue level: 05-489-2010 B 0a.
At the time the ETR220 was developed there was used the older part number system:
example: 220-317-012a
Best regards from Schaudepot Sömmerda
17.05.2017, 10:13 Uhr
soemtron220
Thank you for the excellent explanation.
Was P calculated from xx, yyy and zzzz, or was it just a sequential number 1,2,3.... ?
17.05.2017, 12:09 Uhr
The check digit "P" is calculated from xx, yyy and zzzz.
Next monday I could search for the formula.
17.05.2017, 12:50 Uhr
soemtron220
How are things at Schaudepot Sömmerda ?, any news (not for this discussion, email me).
